Salta al contenuto principale
  1. Start by first removing the battery. Move the first release switch to the right position.
    • Start by first removing the battery.
    • Move the first release switch to the right position.
    • Move the second release switch to the right position while pulling the battery towards the top of the netbook.
  2. Using the bit driver and a Phillips #0 bit, remove the three circled screws, 5 mm in length.
    • Using the bit driver and a Phillips #0 bit, remove the three circled screws, 5 mm in length.
  3. While holding the top of the netbook, flip the netbook over. While holding the top of the netbook, flip the netbook over.
    • While holding the top of the netbook, flip the netbook over.
  4. Kit di riparazione batterie iPhone
    Solo $29.99
    Buy Now
    Solo $29.99
    Buy Now
  5. Carefully lift off the power bar assembly for access to the button and receiver. Carefully lift off the power bar assembly for access to the button and receiver.
    • Carefully lift off the power bar assembly for access to the button and receiver.
  6. Use the spudger to gently pry around the keyboard. This will release the keyboard assembly from the body. Use the spudger to gently pry around the keyboard. This will release the keyboard assembly from the body.
    • Use the spudger to gently pry around the keyboard. This will release the keyboard assembly from the body.
  7. Reach under the keyboard and disconnect the electrical connection. Lift the broken keyboard off.
    • Reach under the keyboard and disconnect the electrical connection.
    • Lift the broken keyboard off.
  8. Reattach the new electrical connection into the old connection location. Place the keyboard into the original location starting with the bottom first. Gently press the keyboard down to secure it into its original location.
    • Reattach the new electrical connection into the old connection location.
    • Place the keyboard into the original location starting with the bottom first.
    • Gently press the keyboard down to secure it into its original location.
Linea Traguardo
Mason McCaskill
Membro da: 18/10/2013
964 Reputazione
9 Guide realizzate
Clemson, Team 14-2, Benson Fall 2013 Membro di Clemson, Team 14-2, Benson Fall 2013
CLEM-BENSON-F13S14G2
3 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 613
