Salta al contenuto principale
Toshiba NB205 N330PK Key Cleaning
Cosa ti serve
  1. Toshiba NB205 N330PK Key Cleaning, Toshiba NB205 N330PK Key Cleaning: passo 1, immagine 1 di 1
    • Using the spudger, gently pry the desired key up on one side. This will release the key.
    • The key is held in place by very small plastic pieces. Improper removal or installation may damage key permanently and require entire keyboard replacement.
  2. Toshiba NB205 N330PK Key Cleaning: passo 2, immagine 1 di 2 Toshiba NB205 N330PK Key Cleaning: passo 2, immagine 2 di 2
    • Use a brush to remove debris and use a cleaner cloth to remove residue.
    • Similarly, remove debris and residue from the area of the keyboard where the key was originally seated.
  3. Toshiba NB205 N330PK Key Cleaning: passo 3, immagine 1 di 1
    • Once clean, set the key above its original position and firmly press it back into place.
    • If cleaned and installed properly the key should depress smoothly and spring back to normal position once released.
Conclusione
This is a complete guide to removing a key and cleaning the area before replacement.
Mason McCaskill
Membro da: 10/18/13
1.000 Reputazione
9 Guide realizzate
Clemson, Team 14-2, Benson Fall 2013 Membro di Clemson, Team 14-2, Benson Fall 2013
CLEM-BENSON-F13S14G2
3 Membri
27 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 479
