Salta al contenuto principale
Toshiba NB205 N330PK Battery Replacement
Cosa ti serve
  1. Toshiba NB205 N330PK Battery Replacement, Battery: passo 1, immagine 1 di 1
    • To release the battery, first slide the switch to the right.
  2. Toshiba NB205 N330PK Battery Replacement: passo 2, immagine 1 di 1
    • Use your right hand to slide the second release switch to the right to unlock the battery.
    • Simultaneously, use your left hand to pull the battery towards the top of the netbook.
  3. Toshiba NB205 N330PK Battery Replacement: passo 3, immagine 1 di 2 Toshiba NB205 N330PK Battery Replacement: passo 3, immagine 2 di 2
    • With a soft or medium bristle brush, gently remove debris from the battery's contacts.
    • Similarly, remove debris from the matching contacts on the netbook itself.
    • Ensure hands and brush are dry to prevent personal injury from electric shock.
  4. Toshiba NB205 N330PK Battery Replacement: passo 4, immagine 1 di 2 Toshiba NB205 N330PK Battery Replacement: passo 4, immagine 2 di 2
    • To reconnect the battery, align these hooks with the designated holes on the netbook.
    • Firmly press the battery back into its original position. A clicking noise should be heard as the switch (bottom switch in photo's orientation) automatically moves.
  5. Toshiba NB205 N330PK Battery Replacement: passo 5, immagine 1 di 1
    • Move the switch to the left position to secure the battery and lock it in place. This ensure a strong battery connection and prevents battery from falling out.
Conclusione
Follow this guide from beginning to end for battery removal, replacement, and cleaning.
Mason McCaskill
Membro da: 10/18/13
1.021 Reputazione
9 Guide realizzate
Clemson, Team 14-2, Benson Fall 2013 Membro di Clemson, Team 14-2, Benson Fall 2013
CLEM-BENSON-F13S14G2
3 Membri
27 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 863
