Salta al contenuto principale
Toshiba NB100 Thermal Pads Replacement
Cosa ti serve
  1. Toshiba NB100 Thermal Pads Replacement, Opening the laptop.: passo 1, immagine 1 di 3 Toshiba NB100 Thermal Pads Replacement, Opening the laptop.: passo 1, immagine 2 di 3 Toshiba NB100 Thermal Pads Replacement, Opening the laptop.: passo 1, immagine 3 di 3
    • Unscrew all screws from the bottom and unplug the battery.
    • Flip the laptop over and by using a prying tool, carefully remove the basel above the keyboard.
    • Remove the 2 screws that hold the keyboard, lift it up, unplug it and set it aside.
  2. Toshiba NB100 Thermal Pads Replacement, Getting to the heat sink.: passo 2, immagine 1 di 3 Toshiba NB100 Thermal Pads Replacement, Getting to the heat sink.: passo 2, immagine 2 di 3 Toshiba NB100 Thermal Pads Replacement, Getting to the heat sink.: passo 2, immagine 3 di 3
    • Carefully unplug the cables and remove the screws that hold the panel in place.
    • Remove the display.
  3. Toshiba NB100 Thermal Pads Replacement, Changing the thermal pads.: passo 3, immagine 1 di 1
    • Lift up the panel and replace the thermal pads. Make sure they are the correct thickness..
    • You can also disconnect the fan and clean it too.
Conclusione
Simeon Brankov
Membro da: 11/08/20
7.153 Reputazione
54 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 275
