Salta al contenuto principale
Toshiba NB100 Keyboard Replacement
Cosa ti serve
  1. Toshiba NB100 Keyboard Replacement, Getting to the keyboard: passo 1, immagine 1 di 2 Toshiba NB100 Keyboard Replacement, Getting to the keyboard: passo 1, immagine 2 di 2
    • Remove the 3 screws holding the panel above the keyboard. The third one should be below the battery, so remove it as well
    • Use a spudger to pop the panel and remove it.
  2. Toshiba NB100 Keyboard Replacement, Removing the old keyboard: passo 2, immagine 1 di 2 Toshiba NB100 Keyboard Replacement, Removing the old keyboard: passo 2, immagine 2 di 2
    • Remove the 2 screws holding the keyboard in place.
    • Carefully lift the keyboard and gently disconnect the cable.
    • Thats it. Remove the old keyboard and replace it with the new one.
Conclusione
Simeon Brankov
Membro da: 11/08/20
7.234 Reputazione
54 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 422
