Salta al contenuto principale
Toshiba Excite 10 AT300 Speaker Replacement
Cosa ti serve
  1. Toshiba Excite 10 AT300 Speaker Replacement, Remove SD Card: passo 1, immagine 1 di 1
    • Remove the SD card from the SD card slot.
  2. Toshiba Excite 10 AT300 Speaker Replacement, Open the Tablet: passo 2, immagine 1 di 3 Toshiba Excite 10 AT300 Speaker Replacement, Open the Tablet: passo 2, immagine 2 di 3 Toshiba Excite 10 AT300 Speaker Replacement, Open the Tablet: passo 2, immagine 3 di 3
    • Use the opening tool to separate the front and rear panels by slipping the tool underneath the screen edge and sliding it around the entire device.
    • Make sure you unclip all of the clips on the back panel, or pulling it off will be difficult and may damage the tablet.
  3. Toshiba Excite 10 AT300 Speaker Replacement, Disconnect Speaker Wires: passo 3, immagine 1 di 3 Toshiba Excite 10 AT300 Speaker Replacement, Disconnect Speaker Wires: passo 3, immagine 2 di 3 Toshiba Excite 10 AT300 Speaker Replacement, Disconnect Speaker Wires: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the speaker cable from its socket by gripping both sides of the white connector piece with tweezers and pulling straight out.
    • Be careful not to rip the wires out of the white connector piece.
  4. Toshiba Excite 10 AT300 Speaker Replacement, Removing Tape: passo 4, immagine 1 di 1
    Compra
    • Using either your hands or tweezers remove the 3 pieces of tape holding the speaker wires to the back panel.
  5. Toshiba Excite 10 AT300 Speaker Replacement, Unscrew Speakers: passo 5, immagine 1 di 1
    • Using a #00 Phillips screwdriver, remove the four 3mm #00 Phillips screws that hold the speakers in place.
    • Using your hands, remove the old speakers from back panel of tablet.
    • Place the new speakers where the old speakers were and in the same orientation.
Conclusione
Cal Poly, Team 14-26, Maness Fall 2014 Membro di Cal Poly, Team 14-26, Maness Fall 2014
CPSU-MANESS-F14S14G26
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 922
