Introduzione
If the rear facing camera on your Toshiba Excite 10 AT300 is now longer functioning, replacement isn't difficult and this guide will give you the step by step procedure. It involves removing a screw, a ribbon cable, and several copper foil wires.
Cosa ti serve
Use the opening tool to separate the front and rear panels by slipping the tool underneath the screen edge and sliding it around the entire device.
Using a #00 Phillips screwdriver, remove the following screws:
Five 3mm Phillips #00 screws
Unlock the ribbon cable housing using tweezers and/or a spudger.
Gently pull the ribbon cable out of its housing using the tweezers or your hands.
Pull copper tape away from the back, keeping it connected to the green rear camera board.
Using your hands remove daughter board by lifting it off of the tablet chassis. Flip it over and place it next to the tablet face-down.
