Salta al contenuto principale
Toshiba Encore Mini Speakers Replacement
Cosa ti serve
  1. Toshiba Encore Mini Speakers Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Encore Mini Speakers Replacement, Battery: passo 1, immagine 2 di 2
    • To replace the battery, the rear cover must first be removed.
    • Using the flat end of the spudger, gently pry open the back case from the rest of the device.
    • It may be easier to start along one of the long edges and carefully work your way toward the corner, then along the short edge.
  2. Toshiba Encore Mini Speakers Replacement: passo 2, immagine 1 di 1
    • Remove the rear cover and set it aside.
  3. Toshiba Encore Mini Speakers Replacement: passo 3, immagine 1 di 1
    • Carefully remove the electrical tape that holds the battery in place.
  4. Toshiba Encore Mini Speakers Replacement: passo 4, immagine 1 di 2 Toshiba Encore Mini Speakers Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using needle-nose tweezers, gently push the large white wire connector (connected to the black, red and blue wires) out of its housing.
  5. Toshiba Encore Mini Speakers Replacement: passo 5, immagine 1 di 1
    • Gently lift the battery out of the device.
    • Be careful not to pull on the connecting wires.
  6. Toshiba Encore Mini Speakers Replacement, Speakers: passo 6, immagine 1 di 1
    • Use the spudger to pull the speaker wire plug from its socket.
  7. Toshiba Encore Mini Speakers Replacement: passo 7, immagine 1 di 1
    • Carefully use the metal spudger to remove the speaker from the frame of the phone.
    • The speaker is attached with some double-sided adhesive and may be difficult to remove.
Conclusione
Khaled Alsaghayer
Membro da: 03/04/17
101 Reputazione
1 Guida realizzata
IUPUI, Team S5-G5, Wilson Spring 2017 Membro di IUPUI, Team S5-G5, Wilson Spring 2017
IUPUI-WILSON-S17S5G5
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 162
