Introduzione
The following guide gives instructions on how to remove the motherboard. This procedure is done in order to replace multiple components. Be sure to avoid damaging any components or connectors removed from the motherboard. It is advised to back up data to an external device before attempting any component replacement.
Cosa ti serve
Using the flat end of the spudger, gently pry open the back case from the rest of the device.
Using needle-nose tweezers, carefully flip up the dark gray cover on the right of the device holding the small orange ribbon in place. (It is approximately 1/4" wide.)
With the tweezers, carefully pull the small ribbon out of its housing. It will stay attached to the device at the other end.
