Salta al contenuto principale
Toshiba Encore Mini Battery Replacement
Cosa ti serve
  1. Toshiba Encore Mini Battery Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Encore Mini Battery Replacement, Battery: passo 1, immagine 2 di 2
    • To replace the battery, the rear cover must first be removed.
    • Using the flat end of the spudger, gently pry open the back case from the rest of the device.
    • It may be easier to start along one of the long edges and carefully work your way toward the corner, then along the short edge.
  2. Toshiba Encore Mini Battery Replacement: passo 2, immagine 1 di 1
    • Remove the rear cover and set it aside.
  3. Toshiba Encore Mini Battery Replacement: passo 3, immagine 1 di 1
    • Carefully remove the electrical tape that holds the battery in place.
  4. Toshiba Encore Mini Battery Replacement: passo 4, immagine 1 di 2 Toshiba Encore Mini Battery Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using needle-nose tweezers, gently push the large white wire connector (connected to the black, red and blue wires) out of its housing.
  5. Toshiba Encore Mini Battery Replacement: passo 5, immagine 1 di 1
    • Gently lift the battery out of the device.
    • Be careful not to pull on the connecting wires.
Conclusione
Altre 5 persone hanno completato questa guida.
UW Tacoma, Team 1-3, Liner SU 2015 Membro di UW Tacoma, Team 1-3, Liner SU 2015
UWT-LINER-SU15S1G3
4 Membri
6 Guide realizzate
2 Commenti
Be sure to remove any SD cards you have first.
ecw0647 - Replica
But where do i buy the battery?
sissyhana - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 4,041
