Salta al contenuto principale
Toshiba Encore 2 WT8-B Battery Replacement
Cosa ti serve
  1. Toshiba Encore 2 WT8-B Battery Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Encore 2 WT8-B Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Lay the tablet face down.
    • Use the Opening pick at the back of the tablet to free the clips. Begin to pull the tool up slightly and work your way around the tablet to free all the clips.
    • Remove the back panel from the tablet.
    • Using a metal prying tool could damage the device.
  2. Toshiba Encore 2 WT8-B Battery Replacement: passo 2, immagine 1 di 3 Toshiba Encore 2 WT8-B Battery Replacement: passo 2, immagine 2 di 3 Toshiba Encore 2 WT8-B Battery Replacement: passo 2, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use a pair of fine tweezers or your fingers to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
    • Repeat on both ends.
    • Make sure to pull out the hinged flap of the ribbon and not the connector.
  3. Toshiba Encore 2 WT8-B Battery Replacement: passo 3, immagine 1 di 1
    • Remove the attached battery wires by pushing the plastic wire holder from right to left on top and bottom part of plastic holder.
    • Be sure to be very gentle when prying colored wires from motherboard to ensure that there is no damage.
  4. Toshiba Encore 2 WT8-B Battery Replacement: passo 4, immagine 1 di 2 Toshiba Encore 2 WT8-B Battery Replacement: passo 4, immagine 2 di 2
    • Use the Phillips #00 screwdriver to remove the seven battery screws connecting the battery to the unit.
  5. Toshiba Encore 2 WT8-B Battery Replacement: passo 5, immagine 1 di 2 Toshiba Encore 2 WT8-B Battery Replacement: passo 5, immagine 2 di 2
    • Remove the battery out of the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,006
