Salta al contenuto principale
Toshiba Encore 2 WT10-A Battery Replacement
Cosa ti serve
  1. Toshiba Encore 2 WT10-A Battery Replacement, Battery: passo 1, immagine 1 di 3 Toshiba Encore 2 WT10-A Battery Replacement, Battery: passo 1, immagine 2 di 3 Toshiba Encore 2 WT10-A Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Start by holding your Toshiba tablet faced up.
    • Flip the tablet from left to right so that you are able to see the back of the tablet.
    • Hold tablet and be ready to continue onto the next steps.
  2. Toshiba Encore 2 WT10-A Battery Replacement: passo 2, immagine 1 di 3 Toshiba Encore 2 WT10-A Battery Replacement: passo 2, immagine 2 di 3 Toshiba Encore 2 WT10-A Battery Replacement: passo 2, immagine 3 di 3
    • Insert a plastic opening tool in the back case of the tablet to free the clips.
    • Begin to pull the tool up slightly and work your way around the tablet to free all the clips.
    • Using a metal opening tool as shown in the photos has the potential to damage your device.
  3. Toshiba Encore 2 WT10-A Battery Replacement: passo 3, immagine 1 di 3 Toshiba Encore 2 WT10-A Battery Replacement: passo 3, immagine 2 di 3 Toshiba Encore 2 WT10-A Battery Replacement: passo 3, immagine 3 di 3
    • Hold back lid with your right hand and keep lifting to remove the back lid.
    • Pull the back lid from right to left and top to bottom.
    • Once you disconnect the back lid, place lid aside.
  4. Toshiba Encore 2 WT10-A Battery Replacement: passo 4, immagine 1 di 2 Toshiba Encore 2 WT10-A Battery Replacement: passo 4, immagine 2 di 2
    • Use plastic spudger to remove the attached battery wires by pushing the plastic wire holder from right to left on top and bottom part of plastic holder.
  5. Toshiba Encore 2 WT10-A Battery Replacement: passo 5, immagine 1 di 3 Toshiba Encore 2 WT10-A Battery Replacement: passo 5, immagine 2 di 3 Toshiba Encore 2 WT10-A Battery Replacement: passo 5, immagine 3 di 3
    • Start by using your left hand on the top left corner on the battery.
    • Then, begin to lift and work your way around the battery.
  6. Toshiba Encore 2 WT10-A Battery Replacement: passo 6, immagine 1 di 2 Toshiba Encore 2 WT10-A Battery Replacement: passo 6, immagine 2 di 2
    • Remove the battery from the compartment.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,662
