Salta al contenuto principale
Toshiba Dynabook T552-58G Space Bar Replacement
  1. Toshiba Dynabook T552-58G Space Bar Replacement, Space Bar: passo 1, immagine 1 di 1
    • The space bar is located on the bottom of the keyboard.
  2. Toshiba Dynabook T552-58G Space Bar Replacement: passo 2, immagine 1 di 2 Toshiba Dynabook T552-58G Space Bar Replacement: passo 2, immagine 2 di 2
    • Gently pry the broken space bar up with from the back with your finger.
  3. Toshiba Dynabook T552-58G Space Bar Replacement: passo 3, immagine 1 di 1
    • You should now see the key retainer.
    • Do not remove anything else because this is crucial for replacing the key.
  4. Toshiba Dynabook T552-58G Space Bar Replacement: passo 4, immagine 1 di 3 Toshiba Dynabook T552-58G Space Bar Replacement: passo 4, immagine 2 di 3 Toshiba Dynabook T552-58G Space Bar Replacement: passo 4, immagine 3 di 3
    • Gently lift up the bottom metal prongs.
    • Insert the two ends of the prong into the small metal loops located at the top of the key pad.
    • Gently press the key down until you hear a click.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 16
Tutti i Tempi: 479
