Salta al contenuto principale
Toshiba Dynabook T552-58G Fan Replacement
Cosa ti serve
  1. Toshiba Dynabook T552-58G Fan Replacement, Back Panel: passo 1, immagine 1 di 1
    • Turn the Toshiba Dynabook T552-58G so that the back panel is facing you.
  2. Toshiba Dynabook T552-58G Fan Replacement: passo 2, immagine 1 di 2 Toshiba Dynabook T552-58G Fan Replacement: passo 2, immagine 2 di 2
    • Remove the 10 screws located on the back panel of the Toshiba Dynabook T552-58G using a PH 0 screwdriver.
    • Each screw will be 5.3 mm long.
  3. Toshiba Dynabook T552-58G Fan Replacement: passo 3, immagine 1 di 3 Toshiba Dynabook T552-58G Fan Replacement: passo 3, immagine 2 di 3 Toshiba Dynabook T552-58G Fan Replacement: passo 3, immagine 3 di 3
    • Remove the black screw using the J0 screwdriver. This is located by the top right foot of the device.
    • This will allow removal of the hard drive cover.
    • This screw will not come out of the hard drive cover.
  4. Toshiba Dynabook T552-58G Fan Replacement: passo 4, immagine 1 di 1
    • Remove the single screw located below the hard drive using the J0 screwdriver. This screw is 5.3 mm long.
  5. Toshiba Dynabook T552-58G Fan Replacement: passo 5, immagine 1 di 3 Toshiba Dynabook T552-58G Fan Replacement: passo 5, immagine 2 di 3 Toshiba Dynabook T552-58G Fan Replacement: passo 5, immagine 3 di 3
    • Remove two screws located diagonally from the bottom-left screw of the hard drive using a J0 screwdriver. The screw closest to the hard drive is 5.2 mm long and the screw farther away is 4.2 mm long.
    • Remove the screw located diagonally from the top right screw of the hard drive using a J0 screwdriver. This screw is 5.2 mm long.
  6. Toshiba Dynabook T552-58G Fan Replacement: passo 6, immagine 1 di 3 Toshiba Dynabook T552-58G Fan Replacement: passo 6, immagine 2 di 3 Toshiba Dynabook T552-58G Fan Replacement: passo 6, immagine 3 di 3
    • Slowly lift the back panel away from the computer.
    • There should be some resistance.
    • Once lifted, carefully remove the back panel.
  7. Toshiba Dynabook T552-58G Fan Replacement, Fan: passo 7, immagine 1 di 1
    • After removing the back panel, locate the fan in the bottom right corner.
    • Make sure computer is turned off and unplugged.
  8. Toshiba Dynabook T552-58G Fan Replacement: passo 8, immagine 1 di 1
    • Remove the two screws located on the top left and bottom right of the fan. You should use a PH 0 screwdriver.
    • Both screws are 2.7 mm long.
  9. Toshiba Dynabook T552-58G Fan Replacement: passo 9, immagine 1 di 2 Toshiba Dynabook T552-58G Fan Replacement: passo 9, immagine 2 di 2
    • Gently lift the fan away from the base. There should be three wires that are connected to the base of the computer through a port.
  10. Toshiba Dynabook T552-58G Fan Replacement: passo 10, immagine 1 di 1
    • With your fingers, carefully pinch the white connector and pull up.
    • There will be some resistance.
  11. Toshiba Dynabook T552-58G Fan Replacement: passo 11, immagine 1 di 1
    • Remove the faulty fan.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 25
Tutti i Tempi: 815
