Salta al contenuto principale
Toshiba Dynabook T552-58G Battery Replacement
  1. Toshiba Dynabook T552-58G Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the computer so that the back panel is facing you.
  2. Toshiba Dynabook T552-58G Battery Replacement: passo 2, immagine 1 di 2 Toshiba Dynabook T552-58G Battery Replacement: passo 2, immagine 2 di 2
    • Push the right battery cover lock (labeled as number 1) to the right.
    • It should now be on the unlock symbol.
  3. Toshiba Dynabook T552-58G Battery Replacement: passo 3, immagine 1 di 1
    • Push and hold the left battery cover lock (labeled as number 2) to the left.
    • It should now be on the number 2.
  4. Toshiba Dynabook T552-58G Battery Replacement: passo 4, immagine 1 di 2 Toshiba Dynabook T552-58G Battery Replacement: passo 4, immagine 2 di 2
    • While holding the left battery cover lock, pull up on the indent found in the center of the battery pack.
    • Lift up on the battery pack to remove it from computer.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 22
Tutti i Tempi: 720
