Introduzione
The back panel is located on the back of the computer. If you need to replace the back panel due to damage, follow this guide. There is one tool needed for this guide.
Cosa ti serve
Turn the Toshiba Dynabook T552-58G so that the back panel is facing you.
Remove two screws located diagonally from the bottom-left screw of the hard drive using a J0 screwdriver. The screw closest to the hard drive is 5.2 mm long and the screw farther away is 4.2 mm long.
Remove the screw located diagonally from the top right screw of the hard drive using a J0 screwdriver. This screw is 5.2 mm long.
