Salta al contenuto principale
Toshiba Dynabook AX 53D Touchpad Replacement
Cosa ti serve
  1. Toshiba Dynabook AX 53D Touchpad Replacement, Battery: passo 1, immagine 1 di 1
    • Push apart the two spring loaded plastic tabs labeled #1 and #2.
    • Make sure to unplug any external power sources before working on the computer.
  2. Toshiba Dynabook AX 53D Touchpad Replacement: passo 2, immagine 1 di 1
    • The battery is now easily removed by pulling up from the notched tab on the inside edge.
  3. Toshiba Dynabook AX 53D Touchpad Replacement, Keyboard: passo 3, immagine 1 di 1
    • Using the #J1 bit, remove the 17 recessed 7.3 mm B6 screws from the underside of laptop and the 3.1 mm #J0 F3 screw inside the battery compartment.
  4. Toshiba Dynabook AX 53D Touchpad Replacement: passo 4, immagine 1 di 2 Toshiba Dynabook AX 53D Touchpad Replacement: passo 4, immagine 2 di 2
    • Run the blue plastic opening tool underneath the media bezel and gently pry from the front panel.
  5. Toshiba Dynabook AX 53D Touchpad Replacement: passo 5, immagine 1 di 1
    • Using the #J0 bit, remove the two 3.1 mm screws securing the top of the keyboard.
  6. Toshiba Dynabook AX 53D Touchpad Replacement: passo 6, immagine 1 di 2 Toshiba Dynabook AX 53D Touchpad Replacement: passo 6, immagine 2 di 2
    • Pop out the black plastic tab on either side of the ribbon cable. Holding the cable on each side, detach from laptop.
  7. Toshiba Dynabook AX 53D Touchpad Replacement, Touchpad: passo 7, immagine 1 di 2 Toshiba Dynabook AX 53D Touchpad Replacement, Touchpad: passo 7, immagine 2 di 2
    • Detach the white plastic end of the braided LCD cable.
  8. Toshiba Dynabook AX 53D Touchpad Replacement: passo 8, immagine 1 di 2 Toshiba Dynabook AX 53D Touchpad Replacement: passo 8, immagine 2 di 2
    • Using the flat metal spatula tool, detach the thin white and black wires from their pop connectors.
  9. Toshiba Dynabook AX 53D Touchpad Replacement: passo 9, immagine 1 di 3 Toshiba Dynabook AX 53D Touchpad Replacement: passo 9, immagine 2 di 3 Toshiba Dynabook AX 53D Touchpad Replacement: passo 9, immagine 3 di 3
    • Using the #J1 Phillips Screwdriver, remove the four 7.6 mm screws that secure the monitor to rest of laptop.
    • The monitor can now be gently removed by lifting upwards.
  10. Toshiba Dynabook AX 53D Touchpad Replacement: passo 10, immagine 1 di 1
    • Run the plastic opening tool along the crease between the top touchpad bezel and bottom section of laptop.
  11. Toshiba Dynabook AX 53D Touchpad Replacement: passo 11, immagine 1 di 2 Toshiba Dynabook AX 53D Touchpad Replacement: passo 11, immagine 2 di 2
    • Gently detach the touchpad bezel.
    • The ribbon cable may break if removed roughly.
    • Gently remove the white ribbon cable.
  12. Toshiba Dynabook AX 53D Touchpad Replacement: passo 12, immagine 1 di 1
    • Remove the six 3.7 mm #J1 screws holding the touchpad in place.
  13. Toshiba Dynabook AX 53D Touchpad Replacement: passo 13, immagine 1 di 1
    • Gently pull the ribbon cable to disconnect it from the touchpad.
  14. Toshiba Dynabook AX 53D Touchpad Replacement: passo 14, immagine 1 di 1
    • Carefully pry up the touchpad with a plastic opening tool.
  15. Toshiba Dynabook AX 53D Touchpad Replacement: passo 15, immagine 1 di 1
    • The touchpad has been removed.
Conclusione
Christopher
Membro da: 03/20/17
525 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 15
Tutti i Tempi: 461
