Salta al contenuto principale
Toshiba Chromebook CB35-A3120 Speakers Replacement
Cosa ti serve
  1. Toshiba Chromebook CB35-A3120 Speakers Replacement, Speakers: passo 1, immagine 1 di 2 Toshiba Chromebook CB35-A3120 Speakers Replacement, Speakers: passo 1, immagine 2 di 2
    • Using a Y1 screw driver head remove all ten .9mm screws from the back cover
    • Set the screws aside in preparation for reassembly
  2. Toshiba Chromebook CB35-A3120 Speakers Replacement: passo 2, immagine 1 di 2 Toshiba Chromebook CB35-A3120 Speakers Replacement: passo 2, immagine 2 di 2
    • Remove the back cover by placing a prying tool in the SD slot and popping the clips out of place.
  3. Toshiba Chromebook CB35-A3120 Speakers Replacement: passo 3, immagine 1 di 3 Toshiba Chromebook CB35-A3120 Speakers Replacement: passo 3, immagine 2 di 3 Toshiba Chromebook CB35-A3120 Speakers Replacement: passo 3, immagine 3 di 3
    • Unscrew the battery by using a J1 screw driver head, and place the four .7mm screws off to the side
    • Using a pry tool, pop the battery connector out of place and gently lift the battery upward.
  4. Toshiba Chromebook CB35-A3120 Speakers Replacement: passo 4, immagine 1 di 3 Toshiba Chromebook CB35-A3120 Speakers Replacement: passo 4, immagine 2 di 3 Toshiba Chromebook CB35-A3120 Speakers Replacement: passo 4, immagine 3 di 3
    • Remove the right side speaker by popping it out of place with your finger
    • Follow the speaker wire along the clips underneath the battery until you reach the left hand speaker
  5. Toshiba Chromebook CB35-A3120 Speakers Replacement: passo 5, immagine 1 di 2 Toshiba Chromebook CB35-A3120 Speakers Replacement: passo 5, immagine 2 di 2
    • Unplug the connector wiring the speaker to the mother board.
    • Pop the speaker out of the computer, similar to the method used in the previous step.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 15-6, Remmell Spring 2017 Membro di USF Tampa, Team 15-6, Remmell Spring 2017
USFT-REMMELL-S17S15G6
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 14
Tutti i Tempi: 746
