Introduzione
In this guide, we will be replacing the battery of the Toshiba Chromebook 2. Many power issues on the Chromebook come from complications with the laptop’s battery. Removing the broken battery and replacing it with a functioning battery will ensure the laptop will keep on running.
Strumenti
Remove the 4 Phillips 2 mm screws holding the battery in place with the Phillips #0 screwdriver.
Altre 47 persone hanno completato questa guida.
5 Commenti
does the cb30-b-103 battery also work with the cb30-b-104 series?
I had four screws holding down battery.
When re-installing cover, don’t get confused. There are two holes under rubber feet on side CLOSEST TO HINGES. These do not accept the two screws - put them on side AWAY FROM HINGES.
Good instructions, my chrome is back to normal again .
Many thanks but now there’s no curser! What do I do?
Chris in UK
Thank you, easy to follow, works like a dream
