Introduzione
This guide will disassemble a Toshiba Canvio Connect V73600-C portable external USB 3 hard drive, specifically model HDTC710AS3A1, which is the silver 1TB model. This guide may work for other Toshiba Canvio models.
Cosa ti serve
On the side of your hard drive casing, insert a spudger.
This can be tricky as the tolerances are quite tight.
I used a needle to make the gap big enough to insert a pick.
Slide your spudger along the gap in the casing you made in the previous step, continuing to open the device.
Slide the spudger around the corner of the casing to start opening the next side.
There may be a gap big enough to see the plastic clips holding the device together.
Once there is a big enough gap in the casing, gently prise the two parts away from each other, being sure not to break any clips.
This will reveal the hard drive in the casing.
Simply lift the drive out of the case.
There may be some friction due to the anti-shock rubber on the corners of the drive.
Gently pry with a plastic pry tool if required.
As the drive has a USB port soldered directly to its logic board, instead of a converter board in between, disassembling this device seems to be pointless unless the hard drive is being used for parts.
Altre 2 persone hanno completato questa guida.
