Salta al contenuto principale
Toshiba Canvio Connect V73600-C Disassembly
Cosa ti serve
  1. Toshiba Canvio Connect V73600-C Disassembly, Begin opening case: passo 1, immagine 1 di 2 Toshiba Canvio Connect V73600-C Disassembly, Begin opening case: passo 1, immagine 2 di 2
    • On the side of your hard drive casing, insert a spudger.
    • This can be tricky as the tolerances are quite tight.
    • I used a needle to make the gap big enough to insert a pick.
  2. Toshiba Canvio Connect V73600-C Disassembly, Continue opening: passo 2, immagine 1 di 1
    • Slide your spudger along the gap in the casing you made in the previous step, continuing to open the device.
  3. Toshiba Canvio Connect V73600-C Disassembly, Keep going: passo 3, immagine 1 di 1
    • Slide the spudger around the corner of the casing to start opening the next side.
    • There may be a gap big enough to see the plastic clips holding the device together.
  4. Toshiba Canvio Connect V73600-C Disassembly, Prise the casing open: passo 4, immagine 1 di 1
    • Once there is a big enough gap in the casing, gently prise the two parts away from each other, being sure not to break any clips.
    • This will reveal the hard drive in the casing.
  5. Toshiba Canvio Connect V73600-C Disassembly, Extract the hard drive: passo 5, immagine 1 di 1
    • Simply lift the drive out of the case.
    • There may be some friction due to the anti-shock rubber on the corners of the drive.
    • Gently pry with a plastic pry tool if required.
  6. Toshiba Canvio Connect V73600-C Disassembly, Realise the drive is not suitable for internal use: passo 6, immagine 1 di 3 Toshiba Canvio Connect V73600-C Disassembly, Realise the drive is not suitable for internal use: passo 6, immagine 2 di 3 Toshiba Canvio Connect V73600-C Disassembly, Realise the drive is not suitable for internal use: passo 6, immagine 3 di 3
    • As the drive has a USB port soldered directly to its logic board, instead of a converter board in between, disassembling this device seems to be pointless unless the hard drive is being used for parts.
Conclusione
Altre 2 persone hanno completato questa guida.
Joel Taylor
Membro da: 03/07/20
1.298 Reputazione
8 Guide realizzate
Australia Membro di Australia
Community
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 49
Ultimi 30 Giorni: 157
Tutti i Tempi: 6,320
