Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
The WIFI PCB is how your device is able to connect to the internet through an antenna. This may need replacement if your device refuses to connect to working WIFI when other devices can connect.
  1. Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool. Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
    • Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
  2. Remove the 10 7.1 mm screws using Phillips #1 screwdriver. Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
    • Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
  3. Loosen the back cover by using a plastic opening tool all the way around the device.
    • Loosen the back cover by using a plastic opening tool all the way around the device.
    • There are areas all along the sides of the device that help aid in this.
    • Be careful when prying, and go slow. The silver plastic frame around the dull gray plastic bottom is fragile and easily dented from prying pressure.
  4. Remove the back cover by gently lifting up on one side of the device. The easiest side to lift up on is the one with the removed rubber foot pads.
    • Remove the back cover by gently lifting up on one side of the device.
    • The easiest side to lift up on is the one with the removed rubber foot pads.
  5. Remove the tape holding the speaker wire to the battery on both sides using a small opening tool. Remove the tape holding the speaker wire to the battery on both sides using a small opening tool.
    • Remove the tape holding the speaker wire to the battery on both sides using a small opening tool.
  6. Remove the 4 Phillips 3.2 mm screws holding the battery in place, with the Phillips #1 screwdriver. Remove the 4 Phillips 3.2 mm screws holding the battery in place, with the Phillips #1 screwdriver.
    • Remove the 4 Phillips 3.2 mm screws holding the battery in place, with the Phillips #1 screwdriver.
  7. To disconnect the wire from the mother board, gently press down with the flat end of Spudger and pull on the wire. Gently shaking the wire from left to right helps with the wire removal Gently shaking the wire from left to right helps with the wire removal
    • To disconnect the wire from the mother board, gently press down with the flat end of Spudger and pull on the wire.
    • Gently shaking the wire from left to right helps with the wire removal
  8. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  9. Remove the battery by gently pulling on the bottom corners. Be careful to move the battery's wire under the speaker's wire.
    • Remove the battery by gently pulling on the bottom corners.
    • Be careful to move the battery's wire under the speaker's wire.
  10. Locate the fan
    • Locate the fan
  11. Unscrew the 4 Phillip screws using a Phillips # 1 Screwdriver.
    • Unscrew the 4 Phillip screws using a Phillips # 1 Screwdriver.
    • These screws only loosen partially, they do not disconnect.
  12. The top wire is the fan's wire. Remove it by pulling it from the motherboard. The top wire is the fan's wire. Remove it by pulling it from the motherboard. The top wire is the fan's wire. Remove it by pulling it from the motherboard.
    • The top wire is the fan's wire. Remove it by pulling it from the motherboard.
  13. To remove the Wifi PCB wire lift up the hinged flap with your finger or with the aid of the spudger tool. After the flap is lifted, pull the wire up out of the connector socket. After the flap is lifted, pull the wire up out of the connector socket.
    • To remove the Wifi PCB wire lift up the hinged flap with your finger or with the aid of the spudger tool.
    • After the flap is lifted, pull the wire up out of the connector socket.
  14. Remove the headphone jack wire by pulling it out of the connector socket. Remove the headphone jack wire by pulling it out of the connector socket.
    • Remove the headphone jack wire by pulling it out of the connector socket.
  15. Remove the Phillip 3.6 mm screw from the fan using a  Phillips #1 screwdriver.
    • Remove the Phillip 3.6 mm screw from the fan using a Phillips #1 screwdriver.
  16. Lift up on the metal plate that hold the screws to start removing the fan.
    • Lift up on the metal plate that hold the screws to start removing the fan.
  17. Once lifted, you will notice that there are two wires tucked under plastic tunnels on the right side of the fan. Remove these wires. These wires require you to gently pull them out of there tunnel. Once the wires are removed the fan should be removed entirely.
    • Once lifted, you will notice that there are two wires tucked under plastic tunnels on the right side of the fan. Remove these wires.
    • These wires require you to gently pull them out of there tunnel.
    • Once the wires are removed the fan should be removed entirely.
  18. The WiFi PCB is located next to the fan.
    • The WiFi PCB is located next to the fan.
  19. Remove the Phillips 3.7 mm screw using a Phillips #1 screwdriver.
    • Remove the Phillips 3.7 mm screw using a Phillips #1 screwdriver.
  20. Gently remove the WiFi PCB by pulling upward.
    • Gently remove the WiFi PCB by pulling upward.
Conclusione
Jillian Thomas
Membro da: 14/10/2017
189 Reputazione
4 Guide realizzate
USF Tampa, Team S1-G121, Cagle Fall 2017 Membro di USF Tampa, Team S1-G121, Cagle Fall 2017
USFT-CAGLE-F17S1G121
3 Membri
14 Guide realizzate
The article has some mistakes, namely, this isn’t the WiFi / WLAN, it is a USB port and card reader slot PCB. I came to iFixIt to double-check the part to upgrade to WiFi 6 (ax). Once you fix the part name, the article is good! The part number DA0BUITH8D0 is what to search for when trying to buy one. I didn’t need one, but looked it up just the same, there are not a ton of these out there and I would probably just resort to a USB reader.
Vic Lovan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 123
