Salta al contenuto principale
Toshiba CB35-C3300 Chromebook 2 SSD Replacement
Cosa ti serve
  1. Toshiba CB35-C3300 Chromebook 2 SSD Replacement, Back Cover: passo 1, immagine 1 di 2 Toshiba CB35-C3300 Chromebook 2 SSD Replacement, Back Cover: passo 1, immagine 2 di 2
    • Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
  2. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: passo 2, immagine 1 di 2 Toshiba CB35-C3300 Chromebook 2 SSD Replacement: passo 2, immagine 2 di 2
    • Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
  3. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: passo 3, immagine 1 di 1
    • Loosen the back cover by using a plastic opening tool all the way around the device.
    • There are areas all along the sides of the device that help aid in this.
    • Be careful when prying, and go slow. The silver plastic frame around the dull gray plastic bottom is fragile and easily dented from prying pressure.
  4. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: passo 4, immagine 1 di 2 Toshiba CB35-C3300 Chromebook 2 SSD Replacement: passo 4, immagine 2 di 2
    • Remove the back cover by gently lifting up on one side of the device.
    • The easiest side to lift up on is the one with the removed rubber foot pads.
  5. Toshiba CB35-C3300 Chromebook 2 SSD Replacement, Battery: passo 5, immagine 1 di 2 Toshiba CB35-C3300 Chromebook 2 SSD Replacement, Battery: passo 5, immagine 2 di 2
    • Remove the tape holding the speaker wire to the battery on both sides using a small opening tool.
  6. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: passo 6, immagine 1 di 2 Toshiba CB35-C3300 Chromebook 2 SSD Replacement: passo 6, immagine 2 di 2
    • Remove the 4 Phillips 3.2 mm screws holding the battery in place, with the Phillips #1 screwdriver.
  7. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: passo 7, immagine 1 di 3 Toshiba CB35-C3300 Chromebook 2 SSD Replacement: passo 7, immagine 2 di 3 Toshiba CB35-C3300 Chromebook 2 SSD Replacement: passo 7, immagine 3 di 3
    • To disconnect the wire from the mother board, gently press down with the flat end of Spudger and pull on the wire.
    • Gently shaking the wire from left to right helps with the wire removal
  8. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: passo 8, immagine 1 di 2 Toshiba CB35-C3300 Chromebook 2 SSD Replacement: passo 8, immagine 2 di 2
    • Remove the battery by gently pulling on the bottom corners.
    • Be careful to move the battery's wire under the speaker's wire.
  9. Toshiba CB35-C3300 Chromebook 2 SSD Replacement, SSD: passo 9, immagine 1 di 1
    • Location of the SSD card
  10. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: passo 10, immagine 1 di 1
    • Remove the Phillips 3.6 mm screw using a Phillips #1 screwdriver.
  11. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: passo 11, immagine 1 di 1
    • Remove the yellow tape by slowly peeling it away at the bottom on the SSD.
  12. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: passo 12, immagine 1 di 2 Toshiba CB35-C3300 Chromebook 2 SSD Replacement: passo 12, immagine 2 di 2
    • Remove the SSD card from the motherboard by gently pulling up on the side where the screw originally was and out in the same direction.
Conclusione
USF Tampa, Team S1-G121, Cagle Fall 2017 Membro di USF Tampa, Team S1-G121, Cagle Fall 2017
USFT-CAGLE-F17S1G121
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 41
Tutti i Tempi: 3,803
