Introduzione
Use this guide to replace the Toshiba A1304T camera.
Cosa ti serve
Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
Using a small Phillips screwdriver, remove the two black screws from the positions indicated.
Gently pull the silver plate from the phone using your fingers.
Quasi finito!
Conclusione
