Salta al contenuto principale
Torque King Electric RTR RC Monster Truck Wheel Replacement
Cosa ti serve
  1. Torque King Electric RTR RC Monster Truck Wheel Replacement, Casing: passo 1, immagine 1 di 2 Torque King Electric RTR RC Monster Truck Wheel Replacement, Casing: passo 1, immagine 2 di 2
    • From the top view, remove each of the four pins that hold the casing in place.
  2. Torque King Electric RTR RC Monster Truck Wheel Replacement: passo 2, immagine 1 di 1
    • Slowly pull the casing up to remove it.
  3. Torque King Electric RTR RC Monster Truck Wheel Replacement, Removing Screws: passo 3, immagine 1 di 1
    • Using a Phillips 1 screwdriver, completely unscrew the 8mm screw located in the center of the wheel. Repeat this step for other wheels if needed.
  4. Torque King Electric RTR RC Monster Truck Wheel Replacement, Removing the Wheel: passo 4, immagine 1 di 1
    • Carefully pull the wheel off of its axle. Repeat for other wheels as necessary.
Conclusione
Erik Rudberg
Membro da: 02/02/15
158 Reputazione
1 Guida realizzata
Cal Poly, Team 6-30, Amido Winter 2015 Membro di Cal Poly, Team 6-30, Amido Winter 2015
CPSU-AMIDO-W15S6G30
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 225
