Salta al contenuto principale
Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement
Cosa ti serve
  1. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Casing: passo 1, immagine 1 di 2 Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Casing: passo 1, immagine 2 di 2
    • From the top view, remove each of the four pins that hold the casing in place.
  2. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement: passo 2, immagine 1 di 1
    • Slowly pull the casing up to remove it.
  3. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Removing Screws: passo 3, immagine 1 di 1
    • Using a Phillips 1 screwdriver, completely unscrew the 8mm screw located in the center of the wheel. Repeat this step for other wheels if needed.
  4. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Removing the Wheel: passo 4, immagine 1 di 1
    • Carefully pull the wheel off of its axle. Repeat for other wheels as necessary.
  5. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Front Wheel Suspension: passo 5, immagine 1 di 2 Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Front Wheel Suspension: passo 5, immagine 2 di 2
    • Pull the top half of the suspension to unclip it.
  6. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement: passo 6, immagine 1 di 1
    • Remove the top clip along with the spring.
  7. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement: passo 7, immagine 1 di 2 Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement: passo 7, immagine 2 di 2
    • Pull up the bottom half of the suspension to unclip it.
Conclusione
Cal Poly, Team 6-30, Amido Winter 2015 Membro di Cal Poly, Team 6-30, Amido Winter 2015
CPSU-AMIDO-W15S6G30
4 Membri
16 Guide realizzate
Un commento
Hola buenas noches, me pueden hacer el favor de ayudarme a armar de nuevo la parte de la suspensiĆ³n de la parte delantera, te go todas las piezas pero no recuerdo como van
Vivian giseli Barrero - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 264
