Introduzione
This guide requires removing the casing and front wheels.
Cosa ti serve
From the top view, remove each of the four pins that hold the casing in place.
Using a Phillips 1 screwdriver, completely unscrew the 8mm screw located in the center of the wheel. Repeat this step for other wheels if needed.
Carefully pull the wheel off of its axle. Repeat for other wheels as necessary.
Un commento
Hola buenas noches, me pueden hacer el favor de ayudarme a armar de nuevo la parte de la suspensiĆ³n de la parte delantera, te go todas las piezas pero no recuerdo como van
