Salta al contenuto principale
Torque King Electric RTR RC Monster Truck Antenna Replacement
Cosa ti serve
  1. Torque King Electric RTR RC Monster Truck Antenna Replacement, Casing: passo 1, immagine 1 di 2 Torque King Electric RTR RC Monster Truck Antenna Replacement, Casing: passo 1, immagine 2 di 2
    • From the top view, remove each of the four pins that hold the casing in place.
  2. Torque King Electric RTR RC Monster Truck Antenna Replacement: passo 2, immagine 1 di 1
    • Slowly pull the casing up to remove it.
  3. Torque King Electric RTR RC Monster Truck Antenna Replacement, Loosen Screw: passo 3, immagine 1 di 1
    • Loosen the 10mm screw surrounded by the copper using a #2 Phillips head screwdriver.
    • The wire that connects the antenna to the circuitry of the truck might be blocking the screw. Take care when moving the wire out of the way not to pull it from its soldering.
  4. Torque King Electric RTR RC Monster Truck Antenna Replacement, Remove Antenna: passo 4, immagine 1 di 1
    • Carefully slide the antenna out from under the screw and remove.
Conclusione
Cal Poly, Team 6-30, Amido Winter 2015 Membro di Cal Poly, Team 6-30, Amido Winter 2015
CPSU-AMIDO-W15S6G30
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 494
