Salta al contenuto principale
Tonneau Trifold Bed Cover Retention Pin Replacement
Cosa ti serve
  1. Tonneau Trifold Bed Cover Retention Pin Replacement, Retention Pin: passo 1, immagine 1 di 3 Tonneau Trifold Bed Cover Retention Pin Replacement, Retention Pin: passo 1, immagine 2 di 3 Tonneau Trifold Bed Cover Retention Pin Replacement, Retention Pin: passo 1, immagine 3 di 3
    • Locate the two screws on the retaining latch.
    • Use an Allen Wrench to loosen the screws.
    • The screws are tight and may require significant force.
  2. Tonneau Trifold Bed Cover Retention Pin Replacement: passo 2, immagine 1 di 2 Tonneau Trifold Bed Cover Retention Pin Replacement: passo 2, immagine 2 di 2
    • Continue loosening the screws until they are both loose enough to remove by hand.
  3. Tonneau Trifold Bed Cover Retention Pin Replacement: passo 3, immagine 1 di 3 Tonneau Trifold Bed Cover Retention Pin Replacement: passo 3, immagine 2 di 3 Tonneau Trifold Bed Cover Retention Pin Replacement: passo 3, immagine 3 di 3
    • Grab both screws and pull them straight out.
    • Line up the holes on the replacement latch, then insert the new screws.
  4. Tonneau Trifold Bed Cover Retention Pin Replacement: passo 4, immagine 1 di 3 Tonneau Trifold Bed Cover Retention Pin Replacement: passo 4, immagine 2 di 3 Tonneau Trifold Bed Cover Retention Pin Replacement: passo 4, immagine 3 di 3
    • Hand tighten both of the bolts onto the new latch.
  5. Tonneau Trifold Bed Cover Retention Pin Replacement: passo 5, immagine 1 di 2 Tonneau Trifold Bed Cover Retention Pin Replacement: passo 5, immagine 2 di 2
    • Tighten both screws evenly until the latch is held firmly in place.
    • Do not over tighten - you could break the Allen Wrench or strip the screws!
Conclusione
To reassemble your device, follow these instructions in order.
Christopher King
Membro da: 01/16/18
139 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 801
