Introduzione
Use this guide if one of the ears has stopped working.
If your button is not broken and only the cable has been torn off, skip the steps to replace the button.
If your button is broken but your cable is not torn off, skip the steps to repair the cable.
Cosa ti serve
The Toniebox is designed as an audiobook player for kids (age three and up), and packs the following features:
Motion control, via slapping the side or tilting the box
Small figurines (Tonies) with built in NFC chip
Soft shockproof shell
Internal storage for up to 400 hours of audio data
7 hours battery capacity
Magnets in the top of the Toniebox, and in the sockets of the Tonies, to keep them stuck together while you tilt and turn the box
Because we're doing this teardown in Germany, we'll forgo the usual metric and imperial measuring shenanigans and simply give you a banana for scale.
Each side of this cube measures 3/4 of a banana. (4.7 inches or 12 cm according to the manufacturer, who evidently did not have a banana handy.)
Placing the banana onto the NFC sensor also doesn't play anything.
Now for the "unboxing".
The main components lift right out the top of the box. Easy peasy.
Surrounding it is this black cage, which is also easy to take out and seems to serve mainly for crush protection.
The squeezable foam bumper comes out last. According to the manufacturer, it's made from sustainable fabrics.
The battery pack and motherboard are secured with just two standard Phillips screws.
As printed on the back, the battery pack consists of three NiMH batteries with a capacity of 2,000 mAh.
The manufacturer states this is a nickel-metal hydride (NiMH) battery pack—chosen because it's a safer technology than lithium-ion, and has almost no memory effect.
We'll have a look at that motherboard just as soon as these stubborn little cables are unplugged. Let's see what all the noise is about! Onboard we find:
Texas Instruments C3200R1M2 microcontroller serving as CPU and WLAN Receiver
ISSI IS25LQ032 flash memory
A Texas Instruments DAC3100 TI 7BI ANVS G4 Audio Controller
Battery loading IC
A TRF7962A RFID Reader to read the NFC chips from the Tonies
NXP MMA8451 accelerometer for fast forward and rewind functions.
And a Sandisk Edge 8 GB MicroSD card formatted as Fat32
Just four more Phillips screws, and we can remove the cap.
Inside the cap we find a second PCB, this one responsible for the NFC connection.
Except for another socket to connect with the motherboard and another crossed out trashcan (WEEE-Symbol), there's nothing to see here.
Next we inspect the volume control buttons, located (rather appropriately) in the ears of the Toniebox.
Removing the outer layer of the ears, we find two small buttons.
Because the buttons connect to the motherboard via a JST plug, we don't need to cut a wire. Lucky us.
That's all, folks! We completely tore down our Toniebox, cut open the lion, and spread everything over the table. Here is our result:
All the screws are standard Phillips screws and no adhesive was used.
The box is easy to disassemble and reassemble, without damaging it or leaving any marks.
Battery pack and flash memory are also pretty common and easy to change.
The cap on the bottom is held in place by plastic clips, which could break if you open the box repeatedly.
Some of the plugs sit in their sockets pretty tight and might be hard to unplug without damaging the sockets.
The headphone jack is soldered to the motherboard.
Remove the ears from the Toniebox according to the basic instructions for the Toniebox Teardown. Be especially careful not to damage the connector on the PCB.
Gently pull the inner ears down and out. Do not pull on the cable!
Use a pair of tweezers to carefully pull the defective button and PCB out of the silicone ear. If the cable is not torn off, be careful not to damage it.
Solder the defective button from the PCB. The best way to do this is to use a hot air gun/ soldering iron around 360 ° C
Remove the excess solder with desoldering braid.
Remove the remains of the torn strand from the solder pads with the soldering iron
Isolate approx. 3mm from each wire of the line
Tin each pad and solder them on the back of the PCB. One wire on each pad. Be careful that the wire has no contact with outer copper surfaces.
Carefully put the circuit board back into the ear.
Lay the strand in the designated channels.
Push the inner ears back into the ear sleeve using the buttons.
Altre 12 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
16 Commenti
Bei unserer Box ist der Schalter samt Platine weg. Kann man das Kabel auch direkt am Schalter anlöten oder hat die Platine eine Funktion?
Hi,
die Platine hat keine elektrische Funktion. Sie dient nur mechanisch dazu den Taster zu stützen. Wenn du es schaffst den direkt anzulöten geht das auch, ich weiss allerdings nicht wie gut das Veralten beim drücken ist oder ob das wider kaputt geht. Hier habe Ich neue Platinen gesehen die man allerdings selbst noch etwas bearbeiten muss:
Hier gibt es auch neue Platinen:
http://www.ebay-kleinanzeigen.de/s-anzei...
Ansonsten hat die keine Funktion. Ihr könnt die Kabel auch an die Taster direkt löten.
Moin
Bei uns sind die ohren durchgeknabert. Ich will nur die orhen erneuern wo kann man die kaufen?
Ich kann gerne einige 3D-Drucken und sie verschicken.
Benoit74 -
