Salta al contenuto principale
TomTom XL Battery Replacement
Cosa ti serve
  1. TomTom XL Battery Replacement, Screen and Motherboard: passo 1, immagine 1 di 1
    • Slip a small plastic opening tool underneath the screen bezel, gently sliding it around the inside edge.
    • Starting at the corners, carefully pry up the screen bezel.
  2. TomTom XL Battery Replacement: passo 2, immagine 1 di 1
    • Remove the four Phillips #00 screws around the edge of the screen.
  3. TomTom XL Battery Replacement: passo 3, immagine 1 di 3 TomTom XL Battery Replacement: passo 3, immagine 2 di 3 TomTom XL Battery Replacement: passo 3, immagine 3 di 3
    • Slide a small plastic opening tool under the top portion of the metal frame and gently lift it up.
    • Slide the plastic opening tool around the inner edge of the metal frame until it feels loose.
    • It may take some time to release the frame from the housing. Some force may be necessary—but be careful not to bend the frame's fragile interior bracket.
    • Remove the frame from the housing.
  4. TomTom XL Battery Replacement: passo 4, immagine 1 di 2 TomTom XL Battery Replacement: passo 4, immagine 2 di 2
    • Lifting from the upper edge of the screen, tilt the screen away from the device.
    • Tilt the screen slowly. Flipping the screen up too quickly may damage the display cable.
  5. TomTom XL Battery Replacement: passo 5, immagine 1 di 2 TomTom XL Battery Replacement: passo 5, immagine 2 di 2
    • Remove the three Phillips #00 screws connecting the motherboard to the plastic housing:
    • Two Phillips #00 screws are located at the bottom of the first picture.
    • The third screw is hidden under the orange ribbon cable, near the screen.
    • You may have to carefully lift the screen in order to reach this screw.
  6. TomTom XL Battery Replacement: passo 6, immagine 1 di 2 TomTom XL Battery Replacement: passo 6, immagine 2 di 2
    • Flip the screen and motherboard over.
    • Gripping the plastic casing, disconnect the battery cable connector from the motherboard.
    • Disconnect the speaker cable connector from the motherboard.
    • Remove the motherboard and screen from the housing.
  7. TomTom XL Battery Replacement, Battery: passo 7, immagine 1 di 1
    • Slip a small plastic opening tool under the battery and slowly pry the battery up.
    • The battery is held on with strong adhesive, so it may require some force. Work slowly and carefully to avoid damaging the housing
    • Remove the battery from the housing.
Conclusione
Altre 13 persone hanno completato questa guida.
Cal Poly, Team 33-84, Johann Spring 2010 Membro di Cal Poly, Team 33-84, Johann Spring 2010
CPSU-JOHANN-S10S33G84
4 Membri
5 Guide realizzate
12 Commenti
Note: There are several variants of this. Some of them have 2 screws on the bottom under the stickers. You'll need to remove those first.
nathan - Replica
Awesome and very detailed guide. Thanks for this.
Phil Harris - Replica
Great demo, for replacement tomtom batteries take a look at : TomTom batteries
based in the UK they are reliable and give a truly longer charge
Kermit45 - Replica
This was a great help. Followed the instructions and it was that easy. Thanks
mark - Replica
nathanrenniewaldock is right... I cracked my screen before finding the hidden screws on the bottom. what a silly company to use the same name for different models!
Laz - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 48
Tutti i Tempi: 51,480
