Introduzione
The TomTom touch screen can stop working or stop responding altogether. This guide will show how to properly remove it.
Cosa ti serve
Position the device so that the underside is facing up.
Tilt the EasyPort Mount slightly upward and rotate it counterclockwise 180 degrees from the initial position.
Firmly grab the EasyPort Mount and remove it.
Wedge a spudger between the white plastic latch and the black connection port, disconnecting the gold ribbon cable.
Slide the gold ribbon cable out of the port.
Use a plastic opening tool to unlatch the screen from its case.
It may be smart to get rid of the first photo and add a photo with the screen and case separated
