Salta al contenuto principale
TomTom VIA 1530 TM Battery Replacement
Cosa ti serve
  1. TomTom VIA 1530 TM Battery  Replacement, Back: passo 1, immagine 1 di 2 TomTom VIA 1530 TM Battery  Replacement, Back: passo 1, immagine 2 di 2
    • Position the device so that the underside is facing up.
    • Tilt the EasyPort Mount slightly upward and rotate it counterclockwise 180 degrees from the initial position.
    • Firmly grab the EasyPort Mount and remove it.
    • If it does not dislodge easily, gently twist the EasyPort Mount, applying increasing pressure until it does.
  2. TomTom VIA 1530 TM Battery  Replacement: passo 2, immagine 1 di 2 TomTom VIA 1530 TM Battery  Replacement: passo 2, immagine 2 di 2
    • Turn the device 180 degrees so the screw in the EasyPort Mount compartment is on top.
    • Remove the 2mm screw beneath the EasyPort Mount compartment with the Torx T-5 head Screwdriver.
  3. TomTom VIA 1530 TM Battery  Replacement: passo 3, immagine 1 di 2 TomTom VIA 1530 TM Battery  Replacement: passo 3, immagine 2 di 2
    • Flip the device over so that the screen is facing up.
    • Wedge the plastic opening tool between the top and bottom of the device's frame, gently sliding it around the outside edge.
    • It may be easier to start at one of the corners.
    • The gold ribbon cable connecting the screen to the motherboard is fragile and tears easily.
    • This specific device's ribbon cable is torn.
  4. TomTom VIA 1530 TM Battery  Replacement: passo 4, immagine 1 di 2 TomTom VIA 1530 TM Battery  Replacement: passo 4, immagine 2 di 2
    • Carefully slide the screen forward, revealing the lower portion of the motherboard.
    • Remove the 3.6mm screw using the JIS #00 Screwdriver.
    • Rotate the device 180 degrees, carefully slide back the screen, and remove the remaining two screws.
  5. TomTom VIA 1530 TM Battery  Replacement: passo 5, immagine 1 di 3 TomTom VIA 1530 TM Battery  Replacement: passo 5, immagine 2 di 3 TomTom VIA 1530 TM Battery  Replacement: passo 5, immagine 3 di 3
    • Disconnect the battery and speaker cables.
    • Unlatch the motherboard from the case.
  6. TomTom VIA 1530 TM Battery  Replacement, Battery: passo 6, immagine 1 di 3 TomTom VIA 1530 TM Battery  Replacement, Battery: passo 6, immagine 2 di 3 TomTom VIA 1530 TM Battery  Replacement, Battery: passo 6, immagine 3 di 3
    • Free the battery cable from its notched position.
    • Use the plastic opening tool to separate the battery from the case.
    • The tearing sound is the adhesive holding the battery tot he case. It will re-stick when you put the battery back in.
Conclusione
Cal Poly, Team S12-G2, Banghart Winter 2018 Membro di Cal Poly, Team S12-G2, Banghart Winter 2018
CPSU-BANGHART-W18S12G2
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 8
Tutti i Tempi: 404
