Introduzione
Before beginning this guide you should have completed guides on removing the back cover and separating the circuit board from the front cover.
Cosa ti serve
Locate the 4 .4mm screws connecting the circuit board to the front panel.
Use the T6 Torx screwdriver and remove the four screws.
Locate the ribbon cable connecting the front panel to the circuit board.
Locate the white tab locking the ribbon in place.
Using precision tweezers push the left and right side of the tab forward.
Gently pull the ribbon to disconnect the circuit board from the front panel.
