Salta al contenuto principale
TomTom ONE Motherboard Replacement
Cosa ti serve
  1. TomTom ONE Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
  2. TomTom ONE Motherboard Replacement: passo 2, immagine 1 di 2 TomTom ONE Motherboard Replacement: passo 2, immagine 2 di 2
    • Using the spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
  3. TomTom ONE Motherboard Replacement: passo 3, immagine 1 di 1
    • Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device.
  4. TomTom ONE Motherboard Replacement: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Once the two covers are separated, use tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover.
  5. TomTom ONE Motherboard Replacement: passo 5, immagine 1 di 1
    • Next, you must remove the motherboard from the front screen.
    • Use a Torx T-7 screwdriver to unscrew the two screws.
  6. TomTom ONE Motherboard Replacement: passo 6, immagine 1 di 2 TomTom ONE Motherboard Replacement: passo 6, immagine 2 di 2
    • Before you can seperate the motherboard from the front cover, you must disconnect the wire connecting the two.
    • To do so, you must use the back end of the spudger to push out the two white tabs connected to the wire, that holds the motherboard and front cover together.
  7. TomTom ONE Motherboard Replacement: passo 7, immagine 1 di 1
    • The motherboard is now disconnected from the front assembly
Conclusione
Altre 4 persone hanno completato questa guida.
Becca
Membro da: 04/16/10
211 Reputazione
2 Guide realizzate
Cal Poly, Team 7-7, Maness Spring 2010 Membro di Cal Poly, Team 7-7, Maness Spring 2010
CPSU-MANESS-S10S7G7
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 10,066
