Salta al contenuto principale
TomTom Go 60 S Lithium Ion Battery Replacement
Cosa ti serve
  1. TomTom Go 60 S Lithium Ion Battery Replacement, Lithium Ion Battery: passo 1, immagine 1 di 1
    • Use the iFixit opening tool to pry open the TomTom Go 60 S. Start from a corner and drag the tool around the device.
  2. TomTom Go 60 S Lithium Ion Battery Replacement: passo 2, immagine 1 di 1
    • Your device should now look like this. Make sure to disconnect the screen from the motherboard by removing the flap connecting both, so you have ample room to work on the device.
  3. TomTom Go 60 S Lithium Ion Battery Replacement: passo 3, immagine 1 di 1
    • Remove all the screws that are marked in the image with a Philips #000 screwdriver and over a magnetic work mat.
  4. TomTom Go 60 S Lithium Ion Battery Replacement: passo 4, immagine 1 di 1
    • Disconnect battery wires from motherboard, so that you can remove the Lithium-Ion battery.
  5. TomTom Go 60 S Lithium Ion Battery Replacement: passo 5, immagine 1 di 1
    • Detach from holster and replace Lithium-Ion battery.
Conclusione
Tomy Peralta
Membro da: 10/04/16
133 Reputazione
3 Guide realizzate
USF Tampa, Team 1-6, Nance Fall 2016 Membro di USF Tampa, Team 1-6, Nance Fall 2016
USFT-NANCE-F16S1G6
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 35
Tutti i Tempi: 2,528
