Salta al contenuto principale
TomTom GO Live 1535M Speaker Replacement
Cosa ti serve
  1. TomTom GO Live 1535M Speaker Replacement, Motherboard: passo 1, immagine 1 di 1
    • Slip a small opening tool underneath the screen, gently sliding it around the outside edge.
    • It may be easier to start at the corners.
  2. TomTom GO Live 1535M Speaker Replacement: passo 2, immagine 1 di 2 TomTom GO Live 1535M Speaker Replacement: passo 2, immagine 2 di 2
    • Carefully remove the reset button cable (located on the left) and the ribbon cable.
    • Remove the screen and set it aside.
  3. TomTom GO Live 1535M Speaker Replacement: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the logic board cables.
    • We highly advice that a pair of tweezers are used for this step to ensure no part is damaged.
  4. TomTom GO Live 1535M Speaker Replacement: passo 4, immagine 1 di 1
    • Remove the 3.6mm screws with a Phillips Screwdriver.
    • After removing the screws simply lift the logic board from the base.
  5. TomTom GO Live 1535M Speaker Replacement, Speaker: passo 5, immagine 1 di 1
    • Simply lift the speaker up and out of the base to replace it.
Conclusione
USF Tampa, Team 19-4, Blackwell Spring 2014 Membro di USF Tampa, Team 19-4, Blackwell Spring 2014
USFT-BLACKWELL-S14S19G4
1 Membro
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 263
