Salta al contenuto principale
TomTom GO Live 1535M Screen Replacement
Cosa ti serve
  1. TomTom GO Live 1535M Screen Replacement, Screen: passo 1, immagine 1 di 1
    • Slip a small opening tool underneath the screen, gently sliding it around the outside edge.
    • To do this, it may be easier to start at the corners.
  2. TomTom GO Live 1535M Screen Replacement, Cables: passo 2, immagine 1 di 2 TomTom GO Live 1535M Screen Replacement, Cables: passo 2, immagine 2 di 2
    • Carefully remove the reset button cable (located on the left) and the ribbon cable.
  3. TomTom GO Live 1535M Screen Replacement, Removing the Screen: passo 3, immagine 1 di 3 TomTom GO Live 1535M Screen Replacement, Removing the Screen: passo 3, immagine 2 di 3 TomTom GO Live 1535M Screen Replacement, Removing the Screen: passo 3, immagine 3 di 3
    • The screen is simply removed by pushing it up-and-out of the outside rim (denoted by the box).
    • As you remove the screen, you may hear a 'tearing' sound. Do not panic, as this is just the leftover substance that holds the screen in place. It will re-stick when the screen in placed back.
    • If you need to find a replacement screen, please click the link here. Link text
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 19-4, Blackwell Spring 2014 Membro di USF Tampa, Team 19-4, Blackwell Spring 2014
USFT-BLACKWELL-S14S19G4
1 Membro
5 Guide realizzate
Un commento
I just replaced the screen. But with the cable ribbon installed the screen does not activate. The startup tom-tom sound does play. The screen is blank. But the old screen does not work as well. Prior to this the screen did work but was un responsive. Any thoughts?
Steven Kawchak - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 873
