Salta al contenuto principale
TomTom GO Live 1535M Reset Button Activation
Cosa ti serve
  1. TomTom GO Live 1535M Reset Button Activation, Reset Button: passo 1, immagine 1 di 1
    • The reset button is located at the top of the device, close to the charging port. It is a small hole that is .78 mm wide.
    • Insert one end of the paper clip into the small power button hole and press down gently until you hear a "click" sound.
    • Hold paper clip in power button hole for 15 seconds.
    • The device should power on by itself with its factory default settings in place once done. If you do not see the screen power on, go back to step 1 and try repowering again.
Conclusione
USF Tampa, Team 19-4, Blackwell Spring 2014 Membro di USF Tampa, Team 19-4, Blackwell Spring 2014
USFT-BLACKWELL-S14S19G4
1 Membro
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 19
Tutti i Tempi: 3,191
