Introduzione
If the device's screen is experiencing problems in its visuals, such as discoloration or image distortion, your device may need a display replacement. Otherwise, if the device does not register touches then you may want to replace the digitizer. Confirm the device is powered off before starting the disassembly.
Cosa ti serve
Unscrew the two 3mm screws at the base of the device using the Torx T5 screwdriver.
Remove the microphone on the left side of the screen casing using tweezers.
Altre 6 persone hanno completato questa guida.
