Salta al contenuto principale
Toilet Tank Assembly Replacement
Cosa ti serve
  1. Toilet Tank Assembly Replacement, Tank Lid: passo 1, immagine 1 di 3 Toilet Tank Assembly Replacement, Tank Lid: passo 1, immagine 2 di 3 Toilet Tank Assembly Replacement, Tank Lid: passo 1, immagine 3 di 3
    • Lift the tank lid up and away from the toilet tank.
  2. Toilet Tank Assembly Replacement, Shutting off the Water Supply to a Toilet: passo 2, immagine 1 di 2 Toilet Tank Assembly Replacement, Shutting off the Water Supply to a Toilet: passo 2, immagine 2 di 2
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
  3. Toilet Tank Assembly Replacement, Draining a Toilet Tank: passo 3, immagine 1 di 2 Toilet Tank Assembly Replacement, Draining a Toilet Tank: passo 3, immagine 2 di 2
    • Push down the flush lever.
    • Hold the lever down until water stops draining from the tank.
    • A small amount of water will remain in the bottom of the tank.
    • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
  4. Toilet Tank Assembly Replacement, Sponge Drying a Toilet Tank: passo 4, immagine 1 di 3 Toilet Tank Assembly Replacement, Sponge Drying a Toilet Tank: passo 4, immagine 2 di 3 Toilet Tank Assembly Replacement, Sponge Drying a Toilet Tank: passo 4, immagine 3 di 3
    • Use a sponge to soak up and remove any remaining water from the toilet tank.
    • Periodically squeeze the excess water from the sponge.
    This is kind of funny but it worked. I had absolutely no sponges at the house, but had leftover diapers our granddaughter outgrew. I thought outside the box and ended up being impressed with the outcome. I opened up the diapers and placed in the remaining tank water. Viola, it immediately began absorbing the water. I used 4 diapers and it did the trick. Just have a leak proof trash bag on hand. No sponge, no bucket, no mess!
    Jody Broussard - Replica
  5. Toilet Tank Assembly Replacement, Supply Tube: passo 5, immagine 1 di 3 Toilet Tank Assembly Replacement, Supply Tube: passo 5, immagine 2 di 3 Toilet Tank Assembly Replacement, Supply Tube: passo 5, immagine 3 di 3
    • Place a bucket under the supply tube to catch any dripping water.
    • Turn the coupling nut on the supply tube clockwise until it releases from the threaded shank on the bottom of the tank.
  6. Toilet Tank Assembly Replacement, Tank Assembly: passo 6, immagine 1 di 3 Toilet Tank Assembly Replacement, Tank Assembly: passo 6, immagine 2 di 3 Toilet Tank Assembly Replacement, Tank Assembly: passo 6, immagine 3 di 3
    • Using a socket wrench to hold the nuts, unscrew the two tank bolts with a screwdriver.
    • When reattaching the tank, tighten the bolts with a screwdriver, rather than tightening the nuts. Alternately tighten each bolt in increments, until the tank fits snugly against the toilet.
    • Avoid over-tightening the tank bolts. Too much force can easily crack the toilet tank or toilet bowl.
  7. Toilet Tank Assembly Replacement: passo 7, immagine 1 di 2 Toilet Tank Assembly Replacement: passo 7, immagine 2 di 2
    • Lift the tank up from the lower half of the toilet.
    • Set the tank on a thick towel to avoid scraping it against the floor.
    The toilet tank can become cracked if not handled carefully.
    bridgettt - Replica
Conclusione
Altre 11 persone hanno completato questa guida.
Ron Davis
Membro da: 02/17/15
31.225 Reputazione
13 Guide realizzate
3 Commenti
Step 5: Clockwise or counter-clockwise depends upon whether you are looking down at the coupling nut from above or up at it from below.
I suspect that, unless it has a left-handed thread, most people would turn it in the direction that works.
John Pretz - Replica
Close your eyes. Attaching something, the turning motion is (usually) clockwise: Righty-tighty; lefty-loosey.
M J McAllister - Replica
Thank you for the info.
DonnaRHellman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 52
Ultimi 30 Giorni: 222
Tutti i Tempi: 12,880
