Salta al contenuto principale
Toilet Seat Replacement
Cosa ti serve
  1. Toilet Seat Replacement, Toilet Seat: passo 1, immagine 1 di 1
    • Measure the size of your toilet bowl to know what size seat to purchase.
  2. Toilet Seat Replacement: passo 2, immagine 1 di 2 Toilet Seat Replacement: passo 2, immagine 2 di 2
    • Twist the tops of the hinges of the currently installed toilet seat and pull toilet seat off to expose the screws.
  3. Toilet Seat Replacement: passo 3, immagine 1 di 3 Toilet Seat Replacement: passo 3, immagine 2 di 3 Toilet Seat Replacement: passo 3, immagine 3 di 3
    • Unscrew the screws to detach the seat.
    • If the screw is not loosening but is spinning as if it were, then hold the back plastic nut so that it can unscrew from the nut.
    • Clean the newly exposed area. This opportunity will not present itself again anytime soon so take advantage of it.
  4. Toilet Seat Replacement: passo 4, immagine 1 di 2 Toilet Seat Replacement: passo 4, immagine 2 di 2
    • Insert new special 20mm screws that are provided with the purchase of the toilet seat in the holes and tighten them.
  5. Toilet Seat Replacement: passo 5, immagine 1 di 1
    • Then re install the toilet seat by fitting the heads of the screws in the holes on the hinges of the seat.
  6. Toilet Seat Replacement: passo 6, immagine 1 di 1
    • Close caps by twisting them in the opposite direction that you did to take off the seat.
Conclusione
To re-install your previous seat, follow these instructions in reverse order.
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 24-5, Green Winter 2015 Membro di Cal Poly, Team 24-5, Green Winter 2015
CPSU-GREEN-W15S24G5
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 41
Tutti i Tempi: 2,148
