Salta al contenuto principale
Toilet Paper Holder Replacement
Cosa ti serve
  1. Toilet Paper Holder Replacement, Toilet Paper Holder: passo 1, immagine 1 di 3 Toilet Paper Holder Replacement, Toilet Paper Holder: passo 1, immagine 2 di 3 Toilet Paper Holder Replacement, Toilet Paper Holder: passo 1, immagine 3 di 3
    • Unscrew the four screws of the original broken holder.
    • You may want to wear gloves.
    • If there is damage to the wall behind the old holder, check out the iFixit guide for repairing a hole in drywall.
  2. Toilet Paper Holder Replacement: passo 2, immagine 1 di 3 Toilet Paper Holder Replacement: passo 2, immagine 2 di 3 Toilet Paper Holder Replacement: passo 2, immagine 3 di 3
    • Measuring the area where you want your new holder to go, mark two lines 6.8" apart.
    • Measure an inch and a third (1 and 1/3") above the marks and mark these new spots where your screws will go.
    • While marking where you want to place the new holder, use a leveling tool to make sure that the toilet paper will be sitting flat.
  3. Toilet Paper Holder Replacement: passo 3, immagine 1 di 3 Toilet Paper Holder Replacement: passo 3, immagine 2 di 3 Toilet Paper Holder Replacement: passo 3, immagine 3 di 3
    • Place the new screw inside the new bracket and line up the mark with the base of the screw.
    • Make sure that the indentation for the toilet paper holder is facing in.
    • Repeat this for the top and bottom screws on both the left and right bracket bases (4 times total).
  4. Toilet Paper Holder Replacement: passo 4, immagine 1 di 3 Toilet Paper Holder Replacement: passo 4, immagine 2 di 3 Toilet Paper Holder Replacement: passo 4, immagine 3 di 3
    • Insert the spring loaded toilet roll bar and enjoy.
Conclusione
Hopefully you have enjoyed exploring this repair guide and now understand how to repair and replace a broken toilet paper roll holder.
Un commento
I don’t like the spring loaded holders. When we moved into our new house two years ago, One of the spring loaded holders was too far apart. Another was two close so roll would not rotate. The other two were ok. I replaced 3 of the 4 with the single arm holder. No need to fiddle with spring loaded holders. Slip on and slip off. Did the same at our previous house. I now have 3 spring loaded holders that I will donate or throw away.
Pete
Pete Chisteckoff - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 49
Tutti i Tempi: 5,237
