Salta al contenuto principale
Toilet Flapper Replacement
  1. Toilet Flapper Replacement, Tank Lid: passo 1, immagine 1 di 3 Toilet Flapper Replacement, Tank Lid: passo 1, immagine 2 di 3 Toilet Flapper Replacement, Tank Lid: passo 1, immagine 3 di 3
    • Lift the tank lid up and away from the toilet tank.
  2. Toilet Flapper Replacement, Shutting off the Water Supply to a Toilet: passo 2, immagine 1 di 2 Toilet Flapper Replacement, Shutting off the Water Supply to a Toilet: passo 2, immagine 2 di 2
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
  3. Toilet Flapper Replacement, Draining a Toilet Tank: passo 3, immagine 1 di 2 Toilet Flapper Replacement, Draining a Toilet Tank: passo 3, immagine 2 di 2
    • Push down the flush lever.
    • Hold the lever down until water stops draining from the tank.
    • A small amount of water will remain in the bottom of the tank.
    • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
  4. Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: passo 4, immagine 1 di 3 Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: passo 4, immagine 2 di 3 Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: passo 4, immagine 3 di 3
    • Squeeze open the spring clasp that connects the pull chain to the tank lever.
    • Disconnect the spring clasp from the tank lever.
  5. Toilet Flapper Replacement, Flapper: passo 5, immagine 1 di 3 Toilet Flapper Replacement, Flapper: passo 5, immagine 2 di 3 Toilet Flapper Replacement, Flapper: passo 5, immagine 3 di 3
    • Disconnect the flapper from the posts on each side of the overflow tube.
    • Remove the flapper from the toilet tank.
Conclusione
Altre 7 persone hanno completato questa guida.
Kristen Gismondi
Membro da: 11/12/14
104.981 Reputazione
266 Guide realizzate
iFixit Membro di iFixit
Staff
124 Membri
25.142 Guide realizzate
2Commenti sulla guida
Thank you I needed that
My Mama - Replica Condividi
How universal is the flapper size? Do I need to measure the existing one before buying a replacement?
John Clements - Replica Condividi
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 72
Ultimi 30 Giorni: 261
Tutti i Tempi: 17,720
