Salta al contenuto principale
Tofu65 Keyboard PCB Replacement
Cosa ti serve
  1. Tofu65 Keyboard PCB Replacement, Keyboard PCB: passo 1, immagine 1 di 1
    • Unplug the power cord.
  2. Tofu65 Keyboard PCB Replacement: passo 2, immagine 1 di 1
    • Use a keycap puller to remove the keycaps from the keyboard.
    • Be sure to pull straight up when removing the keycaps to avoid damaging the key switches.
  3. Tofu65 Keyboard PCB Replacement: passo 3, immagine 1 di 1
    • Use the switch puller to pinch the switch on the two pins to release the switch from the PCB.
    • Pull straight up when removing the switch. It should not take much force to pull them out.
  4. Tofu65 Keyboard PCB Replacement: passo 4, immagine 1 di 2 Tofu65 Keyboard PCB Replacement: passo 4, immagine 2 di 2
    • Remove the plastic cover that protects the PCB.
  5. Tofu65 Keyboard PCB Replacement: passo 5, immagine 1 di 2 Tofu65 Keyboard PCB Replacement: passo 5, immagine 2 di 2
    • Gently remove the foam layer protecting the PCB.
  6. Tofu65 Keyboard PCB Replacement: passo 6, immagine 1 di 3 Tofu65 Keyboard PCB Replacement: passo 6, immagine 2 di 3 Tofu65 Keyboard PCB Replacement: passo 6, immagine 3 di 3
    • Use a Phillips #000 screwdriver to remove the six 5 mm screws keeping the PCB in place.
  7. Tofu65 Keyboard PCB Replacement: passo 7, immagine 1 di 2 Tofu65 Keyboard PCB Replacement: passo 7, immagine 2 di 2
    • Remove the old PCB from the bottom case.
  8. Tofu65 Keyboard PCB Replacement: passo 8, immagine 1 di 2 Tofu65 Keyboard PCB Replacement: passo 8, immagine 2 di 2
    • Ensure your keyboard switches are in good condition and the golden pins are not bent.
    • If the pins are bent, carefully bend them so they are straight or replace them with new switches.
  9. Tofu65 Keyboard PCB Replacement: passo 9, immagine 1 di 3 Tofu65 Keyboard PCB Replacement: passo 9, immagine 2 di 3 Tofu65 Keyboard PCB Replacement: passo 9, immagine 3 di 3
    • Replace your PCB.
    • Place the foam and plastic plate cover back.
    • Line up the key switch pins with the sockets on the PCB before installing them.
    • Install the keyboard switches and apply a small amount of force to ensure they make contact with the PCB.
  10. Tofu65 Keyboard PCB Replacement: passo 10, immagine 1 di 2 Tofu65 Keyboard PCB Replacement: passo 10, immagine 2 di 2
    • Replace each keycaps onto the appropriate switch.
    • Press down firmly on each to ensure they are making contact.
Linea Traguardo
Daniel Payan
Membro da: 03/05/24
202 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 65
Tutti i Tempi: 807
