Salta al contenuto principale
Toaster Oven Toasting Knob Replacement
Cosa ti serve
  1. Toaster Oven Toasting Knob Replacement, Toasting knob: passo 1, immagine 1 di 3 Toaster Oven Toasting Knob Replacement, Toasting knob: passo 1, immagine 2 di 3 Toaster Oven Toasting Knob Replacement, Toasting knob: passo 1, immagine 3 di 3
    • Remove the two 4mm by 8mm screws from the back of the toaster oven.
  2. Toaster Oven Toasting Knob Replacement: passo 2, immagine 1 di 3 Toaster Oven Toasting Knob Replacement: passo 2, immagine 2 di 3 Toaster Oven Toasting Knob Replacement: passo 2, immagine 3 di 3
    • Remove the four 4mm by 8mm screws from the black supports from the base of the toaster oven.
    • Take the two supports off of the bottom.
  3. Toaster Oven Toasting Knob Replacement: passo 3, immagine 1 di 2 Toaster Oven Toasting Knob Replacement: passo 3, immagine 2 di 2
    • Remove the two 4mm by 4mm screws from the base in order to remove the tray.
  4. Toaster Oven Toasting Knob Replacement: passo 4, immagine 1 di 1
    • Slide the back panel off of the oven.
  5. Toaster Oven Toasting Knob Replacement: passo 5, immagine 1 di 1
    • Grip the sides of the metal cover and lift the cover up off the toaster oven top.
  6. Toaster Oven Toasting Knob Replacement: passo 6, immagine 1 di 3 Toaster Oven Toasting Knob Replacement: passo 6, immagine 2 di 3 Toaster Oven Toasting Knob Replacement: passo 6, immagine 3 di 3
    • The knob is missing in the first picture.
    • Push the knob into the hole.
    • The knob is now back in place in the last picture.
Conclusione
Alissa Mell
Membro da: 09/26/17
101 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,892
