Salta al contenuto principale
Toast Master Blender Button Replacement
Cosa ti serve
  1. Toast Master Blender Button Replacement, Blender Button: passo 1, immagine 1 di 3 Toast Master Blender Button Replacement, Blender Button: passo 1, immagine 2 di 3 Toast Master Blender Button Replacement, Blender Button: passo 1, immagine 3 di 3
    • Unplug the plug if connected to any outlets.
    • Take off the cap from the blender and turn the appliance upside down.
    • The blender should be standing upward stably.
  2. Toast Master Blender Button Replacement: passo 2, immagine 1 di 3 Toast Master Blender Button Replacement: passo 2, immagine 2 di 3 Toast Master Blender Button Replacement: passo 2, immagine 3 di 3
    • Use an allen wrench to remove the three screws from the bottom cover.
  3. Toast Master Blender Button Replacement: passo 3, immagine 1 di 3 Toast Master Blender Button Replacement: passo 3, immagine 2 di 3 Toast Master Blender Button Replacement: passo 3, immagine 3 di 3
    • Take off the black blender stand.
    • Take off three silver screws.
    • Put the screws safely aside.
  4. Toast Master Blender Button Replacement: passo 4, immagine 1 di 3 Toast Master Blender Button Replacement: passo 4, immagine 2 di 3 Toast Master Blender Button Replacement: passo 4, immagine 3 di 3
    • Use the Allen wrench to remove the three silver screws on the next level of the blender.
  5. Toast Master Blender Button Replacement: passo 5, immagine 1 di 2 Toast Master Blender Button Replacement: passo 5, immagine 2 di 2
    • Remove the black cap by lifting it upwards and gently placing it aside.
    • Do not pull hard on the wire as this may cause it to break
  6. Toast Master Blender Button Replacement: passo 6, immagine 1 di 3 Toast Master Blender Button Replacement: passo 6, immagine 2 di 3 Toast Master Blender Button Replacement: passo 6, immagine 3 di 3
    • Looking into the internal part of the blender, identify the two silver screws near the button and unscrew them with the screwdriver.
    • Carefully remove two silver screws.
  7. Toast Master Blender Button Replacement: passo 7, immagine 1 di 3 Toast Master Blender Button Replacement: passo 7, immagine 2 di 3 Toast Master Blender Button Replacement: passo 7, immagine 3 di 3
    • Take out the black piece that was attached with the screws and safely place it aside.
  8. Toast Master Blender Button Replacement: passo 8, immagine 1 di 3 Toast Master Blender Button Replacement: passo 8, immagine 2 di 3 Toast Master Blender Button Replacement: passo 8, immagine 3 di 3
    • Take out the button from the blender.
    • This is the plastic button for Toast Master Blender. If you have a spare button, you can replace it.
    • Make sure that side is facing up and place it back into the original position.
    • The button should have a pointier side that resembles a bunny’s head.
  9. Toast Master Blender Button Replacement: passo 9, immagine 1 di 1
    • Press the button and make sure it has a “click” sound.
    • If the button is still loose, go back to the previous step and recheck that the button is in the correct position.
  10. Toast Master Blender Button Replacement: passo 10, immagine 1 di 3 Toast Master Blender Button Replacement: passo 10, immagine 2 di 3 Toast Master Blender Button Replacement: passo 10, immagine 3 di 3
    • Reassemble all the parts back, and screw all the screws back to its original place.
    • All the silver screws are the same size.
    • Make sure the black cap separates rotating paddles and wires.
    • There should be no wires wrapped around the rotating blades.
Conclusione
Jessica Li
Membro da: 02/02/24
181 Reputazione
1 Guida realizzata
UC Davis, Team 4-8, Andersen Winter 2024 Membro di UC Davis, Team 4-8, Andersen Winter 2024
UCD-ANDERSEN-W24S4G8
2 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 66
