Salta al contenuto principale
Tivax STB-T9 Daughter Board Replacement
Cosa ti serve
  1. Tivax STB-T9 Daughter Board Replacement, Daughter Board: passo 1, immagine 1 di 2 Tivax STB-T9 Daughter Board Replacement, Daughter Board: passo 1, immagine 2 di 2
    • Locate Tivax STB-T9 and unplug device from power outlet.
  2. Tivax STB-T9 Daughter Board Replacement: passo 2, immagine 1 di 2 Tivax STB-T9 Daughter Board Replacement: passo 2, immagine 2 di 2
    • Remove the four screws holding the box together. 1 on each side and 2 on the back.
    • You will be using the same Phillips number 2 screw driver(bit P2 in the iFixit tool kit) for the all the screws removed in this guide.
  3. Tivax STB-T9 Daughter Board Replacement: passo 3, immagine 1 di 1
    • Turn the converter upside down.
    • Remove the two screws connecting the face plate the the main box.
  4. Tivax STB-T9 Daughter Board Replacement: passo 4, immagine 1 di 3 Tivax STB-T9 Daughter Board Replacement: passo 4, immagine 2 di 3 Tivax STB-T9 Daughter Board Replacement: passo 4, immagine 3 di 3
    • Once screws are removed, take off case by first pulling up on the back and then sliding away from the front.
    • When putting the case back on, make sure the plastic surrounding the power cord is not in the way or you won't get it all the way on.
  5. Tivax STB-T9 Daughter Board Replacement: passo 5, immagine 1 di 1
    • Locate the white connector attached to the faceplate by black wires.
    • Place your forefinger and thumb on the sides of the connector. With little force, you should be able to pull the connector out.
    • Do not pull on the wire. This could pull them out of of the connector.
  6. Tivax STB-T9 Daughter Board Replacement: passo 6, immagine 1 di 2 Tivax STB-T9 Daughter Board Replacement: passo 6, immagine 2 di 2
    • Locate the daughter board in the face plate.
    • Remove the four screws connecting the daughter board to the face plate.
    • Make sure to keep separate the Daughter Board screws and the case screws.
Conclusione
To reassemble your device please follow the steps in reverse order.
Olivia
Membro da: 02/11/16
1 Reputazione
1 Guida realizzata
Ohio State, Team 1-4, Burgess Spring 2016 Membro di Ohio State, Team 1-4, Burgess Spring 2016
OSU-BURGESS-S16S1G4
4 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 390
