Introduzione
For this guide, you will be removing the back plate to access other parts of the device that need to be replaced. You will need a PH000 Phillips head screwdriver and a plastic opening tool to help remove the back plate.
Cosa ti serve
With the device face down, slide the charging port cover off on the left side of device.
Quasi finito!
To reassemble your device, simply slide the back plate back in to place and press down until you hear several clicks.
Conclusione
