Salta al contenuto principale
Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement
Cosa ti serve
  1. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Safety precautions: passo 1, immagine 1 di 2 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Safety precautions: passo 1, immagine 2 di 2
    • Before you begin, make sure to follow the pressure relief procedure documented in the user manual before powering down the paint sprayer and disconnecting the pump.
    • Turn off and unplug the sprayer.
  2. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the valve handle: passo 2, immagine 1 di 3 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the valve handle: passo 2, immagine 2 di 3 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the valve handle: passo 2, immagine 3 di 3
    • Use a flat punch tool and a hammer to tap the groove pin from left to right out of the valve handle.
  3. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement: passo 3, immagine 1 di 2 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement: passo 3, immagine 2 di 2
    • Remove the valve handle from the cam base.
    • During reassembly, apply grease to the cam base before reattaching the valve handle.
  4. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the cam base: passo 4, immagine 1 di 3 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the cam base: passo 4, immagine 2 di 3 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the cam base: passo 4, immagine 3 di 3
    • Remove the cam base.
  5. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Loosen the bypass valve assembly: passo 5, immagine 1 di 2 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Loosen the bypass valve assembly: passo 5, immagine 2 di 2
    • Use a 13/16" wrench, or an adjustable wrench, to loosen the bypass valve assembly.
    • Rotate the wrench counterclockwise.
  6. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the bypass valve assembly: passo 6, immagine 1 di 2 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the bypass valve assembly: passo 6, immagine 2 di 2
Conclusione
Alex Diaz-Kokaisl
Membro da: 01/16/22
125.112 Reputazione
582 Guide realizzate
iFixit Membro di iFixit
Staff
136 Membri
17.432 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 27
Tutti i Tempi: 492
